#1 01-02-2016 13:33:34
TractionBL
The best oil for the gearbox 11BL
Hello I have sae  80w-140 in my gearbox and I woulk like to know if with sae 140 the gearbox when is cool it run best. Someone put sae 140 in the gearbox ?  thank you very much
#2 01-02-2016 14:44:33
barbedette
Re : The best oil for the gearbox 11BL
Yes, I have been using this one for the past ten years or more without any problem.
Dernière modification par barbedette (01-02-2016 14:45:04)
Alain (PAU 64)-74 ans
11BL54
#3 01-02-2016 15:39:36
JP A
Hello "you" ;-))
Why do you think your car runs better when gearbox is cool with SAE140 oïl ?
It's a thick, very thick oïl...
SAE 90 or 80W90 should fit better, (like this one : http://www.racinglubes.fr/74-castrol-ep … tjI8P8HAQ)
API GL4 spec (important, not GL5)
EP is also important, because of powers on gearbox pinions...
Better oïl brands (OMHO) are CASTROL, YACCO and MOTUL
Regards
JP
#4 01-02-2016 16:58:58
MARC91150
Hello,Traction BL ; JP is OK
I use EXTREME PRESSURE 80 W 90 with Castrol Api GL4
Dernière modification par MARC91150 (01-02-2016 16:59:52)
#5 01-02-2016 18:01:03
La  Monograde SAE 140, c'est plutôt pour les Rosalie
#6 01-02-2016 21:54:46
TractionBL
Ok, thank you for your help, I have in the car 80w-140  and when the car is cool  betweenn first and second it is easy make noise when I change gear . But when the car is hoot don,t make noise when I change the gear .
#7 02-02-2016 22:06:03
yann 30
Solution: don't change gear when the car is cool !
lol
#8 02-02-2016 22:41:33
Change speeds slowly or make a "double pédalage" when the gearbox is cold
#9 03-02-2016 10:32:18
barbedette
As I said higher up in this post I have been using a 85W-140 oil for many years without problem, even in cold weather. If you have difficulties shifting the gears when the oil is cold, the problem is somewhere else.
Como lo decía mas arriba, estoy utilzando un aceite 85W-140 desde muchos años sin problema, aun en temporada fria. Si tienes difficuldades para cambiar las marchas tu problema es otro.
11BL54
