Hello I have sae 80w-140 in my gearbox and I woulk like to know if with sae 140 the gearbox when is cool it run best. Someone put sae 140 in the gearbox ? thank you very much
Hello "you" ;-))
Why do you think your car runs better when gearbox is cool with SAE140 oïl ?
It's a thick, very thick oïl...
SAE 90 or 80W90 should fit better, (like this one : http://www.racinglubes.fr/74-castrol-ep … tjI8P8HAQ)
API GL4 spec (important, not GL5)
EP is also important, because of powers on gearbox pinions...
Better oïl brands (OMHO) are CASTROL, YACCO and MOTUL
Regards
JP
Hello,Traction BL ; JP is OK
I use EXTREME PRESSURE 80 W 90 with Castrol Api GL4
Dernière modification par MARC91150 (01-02-2016 16:59:52)
La Monograde SAE 140, c'est plutôt pour les Rosalie
Ok, thank you for your help, I have in the car 80w-140 and when the car is cool betweenn first and second it is easy make noise when I change gear . But when the car is hoot don,t make noise when I change the gear .
Solution: don't change gear when the car is cool !
Change speeds slowly or make a "double pédalage" when the gearbox is cold
As I said higher up in this post I have been using a 85W-140 oil for many years without problem, even in cold weather. If you have difficulties shifting the gears when the oil is cold, the problem is somewhere else.
Como lo decía mas arriba, estoy utilzando un aceite 85W-140 desde muchos años sin problema, aun en temporada fria. Si tienes difficuldades para cambiar las marchas tu problema es otro.
Alain (PAU 64)-74 ans
11BL54
