#1 09-12-2015 20:35:44
TractionBL
Buy direction complete
Hello I have a problema with the direction of my Traction BL . It has a lot use and it is looseness . I have see in internet in Pat2D a complete direction for a BL restored. Something has buy a direction in this page ? It is a good qualiti in this page ? thank you I hope your answer
#2 09-12-2015 21:56:33
Bobby
Re : Buy direction complete
Hi,
I never boughtt direction, but I recently boughtt other stuff on Pat2D and I had no problem with those (or the delivery) for now, so I guess qualityy is good enough.
I know that more experienced members on that forum are suspicious on new-manufactured pieces, but in your case it's a restored one. Maybe you can have more details and photos by calling Pat2D to be sure ?
(sorry for double letters at the end of some words, but the forum seems to not really enjoying the fact that i use preterit and some other english words because it replace the correct words by some other nonsense words...)
Bye !
Dernière modification par Bobby (09-12-2015 22:02:32)
Bobby - 31 ans - Marseille - 11 BL "transition" Juillet 1952 (Malle plate, pares chocs moustaches et essuies glaces en bas)
#3 09-12-2015 22:35:01
Il peut aussi contacter Jean-Luc de Négotroc !!!!
http://www.negotroc.fr/index.php
Dernière modification par LR539 (12-12-2015 10:18:47)
#4 10-12-2015 09:22:03
Y1115
si Jean-Luc n'en a pas j'en ai, mais d'abord les pros @+
#5 12-12-2015 10:13:27
Merci Michel et Yves, il m'a contacté, c'est la même direction que Patrick et Gégé, celle avec un tube de 475mm en acier
#6 12-12-2015 10:19:20
sa trac va avoir une santé de fer !!!
