Hello I have a problema with the direction of my Traction BL . It has a lot use and it is looseness . I have see in internet in Pat2D a complete direction for a BL restored. Something has buy a direction in this page ? It is a good qualiti in this page ? thank you I hope your answer
Hi,
I never boughtt direction, but I recently boughtt other stuff on Pat2D and I had no problem with those (or the delivery) for now, so I guess qualityy is good enough.
I know that more experienced members on that forum are suspicious on new-manufactured pieces, but in your case it's a restored one. Maybe you can have more details and photos by calling Pat2D to be sure ?
(sorry for double letters at the end of some words, but the forum seems to not really enjoying the fact that i use preterit and some other english words because it replace the correct words by some other nonsense words...)
Bye !
Dernière modification par Bobby (09-12-2015 22:02:32)
Bobby - 31 ans - Marseille - 11 BL "transition" Juillet 1952 (Malle plate, pares chocs moustaches et essuies glaces en bas)
Il peut aussi contacter Jean-Luc de Négotroc !!!!
http://www.negotroc.fr/index.php
Dernière modification par LR539 (12-12-2015 10:18:47)
si Jean-Luc n'en a pas j'en ai, mais d'abord les pros @+
Merci Michel et Yves, il m'a contacté, c'est la même direction que Patrick et Gégé, celle avec un tube de 475mm en acier
sa trac va avoir une santé de fer !!!
